V
vinash
Živjo,
Rabim AT89C4051 izkoristiti kot AD pretvornik za uporabo kot dvomestna Voltmeter.Jaz sem po vezje modela glede na naslednjem naslovu:
h ** p: / / www.atmel.com/dyn/resources/prod_documents/DOC0524.PDF.
Napisal sem kodo v C, in to ne dela in tudi jaz nisem mogla zbrati prevajalnik pravi nekaj podobnega "scanled auto segment prevelik".Bilo bi zelo koristno, če bi nekdo, da mi pomaga, če obstajajo napake v mojem kodo.Moja številka je:
# include <AT89x051.h>
# define TON 79;
# define Kicoš 79;
sbit COMP_INP = P3 ^ 6;
static int ta, tb;
void zamudo (char count);
char [10] = (0x07, 0x17, 0x27, 0x37, 0x47, 0x57, 0x67, 0x77, 0x87, 0x97);
char b [10] = (0x0B, 0x1B, 0x2B, 0x3B, 0x4b, 0x5B, 0x6B, 0x7B, 0x8B, 0x9B);
scanled ();void main (void)
int td, tc, m;
TC = TON;
td = Kicoš;while (1) (
ta = tb = 0;
P3_7 = 1;
for (m = 0, m <= tc; m ) (
if (COMP_INP == 0)
ta ;
zamude (7);
P3_7 = 0;
for (m = 0, m <td; m ) (
if (COMP_INP == 1)
TB ;
zamude (7);
scanled ();
scanled () (
unsigned int i, zastava, r, q;
char voltage1 [79] = (0,0,0,1,1,2,2,3,3,4,4,4,5,5,6,6,6,7,7,8,8,8 , 9,9,10,10,10,11,11,11,12,12,12,13,13,13,14,14,14,15,15,15,16,16,16,17,17 , 17,18,18,18,18,19,19,19,20,20,20,20,21,21,21,22,22,22,22,23,23,23,23,24,24 );
char voltage2 [79] = (50,49,49,48,48,47,47,46,46,45,45,45,44,44,43,43,43,42,42,41,41,41 , 40,40,39,39,39,38,38,38,37,37,37,36,36,36,35,35,35,34,34,34,33,33,33,32,32 , 32,31,31,31,31,30,30,30,29,29,29,29,28,28,28,27,27,27,27,26,26,26,26,25,25 , 25,25,25,24,24,24,24);
if (tb == 0) (
q = voltage1 [ta];
for (i = 0; i <2; i ) (
flag = 1-i;
if (zastava == 1) (
P1 = [q/10];
zamude (1);
P1 = 0xFF;
if (zastava == 0) (
P1 = b [q% 10];
zamude (1);
P1 = 0xFF;
if (ta == 0) (
r = voltage2 [TB];
flag = 1-i;
if (zastava == 1) (
P1 = [r/10];
zamude (1);
P1 = 0xFF;
if (zastava == 0) (
P1 = b [r% 10];
zamude (1);
P1 = 0xFF;
char j, l;
for (j = 0; j <= count; j )
for (l = 0; l <= 120; l );
Resnično upam, kdo bi lahko pomagal.Hvala.
# define TON 79;
# define Kicoš 79;
static int ta, tb;
int td, tc, m;
TC = TON;
ta = tb = 0;
P3_7 = 1;
if (COMP_INP == 0)
ta ;
zamude (7);
P3_7 = 0;
if (COMP_INP == 1)
TB ;
zamude (7);
scanled ();
scanled () (
if (tb == 0) (
q = voltage1 [ta];
flag = 1-i;
if (zastava == 1) (
P1 = [q/10];
zamude (1);
P1 = 0xFF;
if (zastava == 0) (
P1 = b [q% 10];
zamude (1);
P1 = 0xFF;
if (ta == 0) (
r = voltage2 [TB];
flag = 1-i;
if (zastava == 1) (
P1 = [r/10];
zamude (1);
P1 = 0xFF;
if (zastava == 0) (
P1 = b [r% 10];
zamude (1);
P1 = 0xFF;
char j, l;
